GP Clutch Lever
Hector GP
10-17-2006 09:52:24
What do I need to adjust so the clutch lever ingauges easier? Thanks
Kurt_JDB
10-18-2006 07:50:36
 Re: GP Clutch Lever in reply to Hector GP , 10-17-2006 09:52:24
Hector,
If the clutch is set up like a typical JD 2-cylinder tractor,The force it takes to engage (and disengage) the clutch is adjusted by three castellated nuts that you access after popping off the clutch cover. The clutch adjusting procedure should be in the owners manual for your tractor.
What you are adjusting is the overall distance between the various clutch disks and pressure plates when the clutch is disengaged. As you tighten the nuts, the distance between these parts is less, and it takes more force to operate the clutch dogs, which force and then hold everything together.
A few important things to keep in mind are:
The nuts must be adjusted evenly, or the clutch will stutter or grab when engaged.
If it too loose, The clutch will slip under load.
Be sure to put cotter pins back in thru the nut after adjusting the clutch.
Good luck.
Kurt
Hector GP
10-18-2006 14:45:56
 Re: GP Clutch Lever in reply to Kurt_JDB, 10-18-2006 07:50:36
Thanks for the good info I do have a manual on the way. Tanks again
