60 Engine Rebuild costs
Pattock
10-17-2006 04:06:42
I was wondering if anyone on the sight has recently rebuilt a 60 engine? If so could you explain the level of rebuild and the costs. Someone told me costs to rebuild could be well oover $2000, and I find that hard to believe.
PAttock
10-17-2006 18:24:27
 Re: 60 Engine Rebuild costs in reply to Pattock, 10-17-2006 04:06:42
Thanks guys your replies help give me a good idea
Kent Petersen
10-17-2006 17:28:43
i am doing one right now for a frind. am taking down to bare crank case in the engine area. much rust new pistons and rings 500.00 manifold 150.00 gasket set 125.00 boreing 200.00? misc gaskets seals bolts waterpump kit250.00? labor estm 750to 1000 you get to 2000.00 plus real fast
Blksmok
10-17-2006 08:13:51
Pattock..recent prices on 70D rebuild:
main bearings-->$270
rod bearings--->$106
rings--->$165
crank grind--->$260
head rebuild--->$200
Gaskets/Seals--->$120
Block did not require boring. Used existing pistons.
buickanddeere
10-17-2006 14:26:15
 Re: 60 Engine Rebuild costs in reply to Blksmok, 10-17-2006 08:13:51
Don't forget regrinding the cam and re-facing the cam followers. Doesn't matter how good the rest of the engine is. If the cam is worn or out of time, the engine will not run correctly. $500.00 won't bring home a set of new pistons, rings and pins.
machinery-man
10-17-2006 07:07:13
Your approach is the cost factor. If you hone and rering some bearings, little head work you might be speaking of $300-400 but if you want to start using machine work, new pistons, rebuilt head you could start approaching that figure. Personally, I"ve had just as good an outcome on the first mentioned procedure depending on condition of parts. Some extra clearance will not be a factor as long as you get the ridge honed. This will be on the upper part of cylinder wall. You may find damaged rings or worn pistons and I"ve always found good used parts worked just fine. Would recommend one piece oil rings and JD parts.
Avery-MS
10-17-2006 06:22:47
I can't tell you about a model 60 but I just had MT rebuilt totally (bored block, crank turned, head completely reworked) and it cost me $1819. The engine was stuck - big time. Everything had to be repaired/replaced. In addition to the $1819 I bought a few parts off e-bay to put in the engine so I have a good $2000 in it.
Mike M
10-17-2006 04:40:56
Parts are getting more expensive everyday and so is machine shop work. I would hate to guess ,but that $2,000 figure could come up real fast if you need to bore it and do crank work. That would be about as good of figure to budget as any.
