DLTX-3, removing the 2 plugs in stem?
bmklawt
10-16-2006 20:43:30
There are 2 steel plugs on the stem (the part the bowl covers)
Should I remove them as long as I am rebuilding the carb?
How do you remove them?
Your help is much appreciated,
Bruce
Duane Larson
10-17-2006 11:59:13
 Re: DLTX-3, removing the 2 plugs in stem? in reply to bmklawt, 10-16-2006 20:43:30
Bruce,
You don't need to remove them. There may be a steel plate in there, but the ones I have rebuilt have solder covering them up. They must be for manufacturing as they provide no useful access to anything (the acceleration well volume around the nozzle is accessible thru the bottom of the neck). Just remove the brass screw plugs and clean all passages. As I recall there are 3 brass screw plugs on the DLTX3 - it's for a D from s/n 49774-109943.
Mike M
10-17-2006 04:47:11
What tractor does that fit ???
Are you sure there not brass plugs ? If so heat them up with a real torch then let them cool off and they should screw right out. You won't get it clean until you get them out. One of them should have "the secret idle passage" behind it.
bmklawt
10-17-2006 11:19:48
 Re: DLTX-3, removing the 2 plugs in stem? in reply to Mike M, 10-17-2006 04:47:11
They are steel plugs and it's plain to see they have been soldered in. There is no slot in the plug for a screwdriver.
Thanks again
Mike M
10-17-2006 11:35:36
 Re: DLTX-3, removing the 2 plugs in stem? in reply to bmklawt, 10-17-2006 11:19:48
Is this on a duplex carb. off of a later numbered series 2 cyl ? If so those may be ball bearings driven in the hole to seal it off. I'd leave those alone as removing them may cause more damage than good.
Mike M
10-17-2006 11:44:49
 Re: DLTX-3, removing the 2 plugs in stem? in reply to Mike M, 10-17-2006 11:35:36
I just went over to www.robertscarbrepair.com and it appears that carb. is for a model D I think the slang term is a "tennis ball bowl carb." It's been along time since I had one of those apart. Might be a good idea to give Roberts carb. a call and ask them for sure.
