3020 electical installation help
WheredaFoxhat
10-16-2006 18:40:08
I have to mount a new baler computer (New Holland Bale command w/ a 648 Silage Special baler) on my O/S 68 3020 Dsl(S/N 85297). I know the tractor is 24VDC but the lights and such are 12VDC. Has any one mounted anything similar? The JD operator"s manual talks about balancing the bateries if anything over a 3 amp load is installed. The computer manual talks about a 30 amp and a 20 amp internal breaker. Also, does anyone have any experience mounting all this stuff without wholesale destruction of the sheet metal? My tractor was recently restored, and I would like to keep it as whole as possible. Thanks for the help.
buickanddeere
10-18-2006 19:05:12
 Re: 3020 electical installation help in reply to WheredaFoxhat, 10-16-2006 18:40:08
As stated before. A separate independent 12V alternator and battery added to the tractor is your quickest and cheapest way. There are 24V generators rated for 18amp used on the later 840's etc. And there are 24V isolated alternators as well. That cures the slow charging but unbalanced loads will still doom the one battery.
Gerald J.
10-17-2006 10:15:47
John T. has covered the fundamentals with one exception. That is the power available from the 24 generator. Its only 10 amps and if your computer really needs 20 or 30 amps to run baler controls, the generator isn't going to keep up, to say nothing of the load being on one battery which won't be charged while the other battery gets overcharged. You need to learn the real load the computer has to know whether this is workable.
Gerald J.
John T
10-17-2006 10:29:00
 Re: 3020 electical installation help in reply to Gerald J., 10-17-2006 10:15:47
Gerald, if thats reallyyyyy yyyy ONLY a computer???? (which I kinda doubt) I dont see it needing but a few amps max, buttttt tt my buddy has a big round baler with a 12V DC Motor on board that ties the bales and I bet that isssss s something like 10 to 15 amps.
I agree we gotta know the true load and we sure dont from sittin here lol. He may need some sort of a solid state voltage regulator regulator device that uses 24 volts in and has 12 volts out so he keeps his batteries balanced.
John T
Gerald J.
10-17-2006 12:24:38
 Re: 3020 electical installation help in reply to John T, 10-17-2006 10:29:00
Really that would have to be a 24 volt in (and floating) to 12 volt power supply. They do exist, stock parts at electronics distributors like Mouser.
Lots of laptops take 4 amps at 18 volts so they would draw 6 amps at 12 volts with their 12 volt adapter.
The fundamental problem is that the generator only puts out 10 amps on the diesel 3020 and 4020 and that takes all day to recharge after a start and won't catch up that fast with the lights on.
Now may be the time to do the 24 to 12 volt conversion which needs an alternator with the right pulley, new battery cables, a new starter and starter solenoid, and some load rewiring. The starter is the expensive part, last I saw it priced Deere wanted about $600 for their kit. Others may sell the parts for less. If I could find room I'd seriously consider hanging a skinny Delco 130 or Japanese) alternator under or over the generator with its own regulator and battery to run the baler computer. It would be cheaper than the complete conversion. It would even be possible to tap into the tractor hydraulics and run that alternator with a hydraulic motor to make life a lot simpler mechanically.
The generators used in the new generation tractors didn't anticipate short periods of use or significant added loads like lights and computers and solenoid valves.
I wasn't happy with my gas 4020 (12 volt positive ground) when I kept having to put a charger on the battery after it sat a while before I could put it to work. Nor with one year battery life of that $89 battery. So I polished up the generator commutator , replaced the brushes (which I fitted properly) and replaced the worn out belt and generator pulley. That didn't cure things so I drilled the dash (where it was marked from the back for another 2" gauge used with the powershift) transmission and wired in an ammeter. All it did was swing from peg to peg. The voltage regulator wasn't much good and was vibrating slowly. A new voltage regulator was $35 so for $50 I got the local auto electric shop to make me up a one wire 10-SI with the wide pulley and an adapter that fit the generator bracket. After that the expensive battery lasted several years, and now I've put on a new step and a side terminal battery close to th starter and that $39 battery lasted 3 years. The ammeter tells me the alternator is taking good care of the battery too. And now I have excess electric power for running my sprayer pump that takes about 10 amps and anything else I want to add.
Gerald J.
John T
10-17-2006 07:21:20
Fox, I have no experience with New Generation and can only provide some theoretical insight which may or may not help one bit. Its true the battery loads are best kept as balanced as possible for better and more equal battery life and charging, but you can ONLY feed 12 volts (Neg ground) to that baler from ONLY ONE BATTERY and that being the one thats Negative to frame grounded. That tractor uses two 12 volt batteries in series for the Starter Motor and Generator which are two wire isolated from frame ground devices. However, where the two batteries are tied together to form the series connection, that mid tie point is also bonded to frame ground. Therefore, 12 volts exists at the outermost untied terminal on BOTH batteries with respect to frame ground with one Battery being Negative grounded and the other Positive grounded. To feed 12 volts Negative ground to the computer, you would use the battery that has its outermost untied terminal + (goes to starter) for 12 volts Positive and its other inner tied - post being the one thats bonded to the frame i.e. whichever battery that has its - post to frame ground at the mid tie point where the 2 batteries are joined together..... .. If you put say a 20 amp (or whatevers required, I doubt that much current) circuit breaker on the + battery post (battery that has its other - post tied to frame) and the other lead tied to frame ground, theres the 12 volts negative ground feed for the baler.
Clear as mud????? ??? You can only use ONE battery for 12 volts DC, so use the + post on whichever battery has its - post tied to frame ground..... .that gives you 12 Volts DC Negative Ground.
John T
