730 powersteering problems
farmhand
10-16-2006 17:32:27
I had to replace the radiator on my 730 and have had all the lines, steering shaft, and worm gear out so I could get the radiator out.I have it back together now but when I started the tractor the steering turned to the right and seems to be locked up. It seems as though it may have air in the lines or have I put something back together wrong. The powersteering pump also seems to be getting hot. Does anyone have any advise?
Mike M
10-17-2006 06:11:18
 Re: 730 powersteering problems in reply to farmhand, 10-16-2006 17:32:27
Did you put a mark on the steering valve and install it back in the same spot ? This valve is real touchy about where it gets set. An I&T book will tell which way you need to move it to forward or backwards in relation to which way it drifts off.
