48-A Connecting Rod Lubrication
Sam Schudi
10-16-2006 13:49:33
Are the Connecting Rod / Crankshaft bearings lubricated by a wet or splash sump? If that is the case, does the connecting rod actually touch the oil in the sump at the bottom of it's stroke?
Glen in TX
10-16-2006 15:51:04
 Re: 48-A Connecting Rod Lubrication in reply to Sam Schudi, 10-16-2006 13:49:33
Oil pump sends oil to main bearings via some oil lines and the crankshaft is cross drilled from main bearings over to the rod journals and that is how rod bearings get oiled.
Sam Schudi
10-16-2006 19:50:17
 Re: 48-A Connecting Rod Lubrication in reply to Glen in TX, 10-16-2006 15:51:04
So a connecting rod bearing failure could be caused by some blockage in that channel through the crank? Or maybe just a warn bearing?
Thanks for your advice!
Glen in TX
10-16-2006 21:20:40
 Re: 48-A Connecting Rod Lubrication in reply to Sam Schudi, 10-16-2006 19:50:17
Could have been caused by several things but once the rod bearings are worn enough to knock and some babbit tears off blocking oil hole or insert bearing spins blocking the hole then it can't get oiled and gets hot. Same thing can happen with main bearing spinning blocking hole to rod on that side of crank too. Oil line could have broke inside? Maybe oil pump sheared a drive gear key too? Several things to look for why it happens.
