2240 or 2840
piston
10-16-2006 12:34:46
what about these tractors? are they fairly good are exc. good doesanyone know value of them? 2240 1700 hrs 2840 has 3000 hrs on them,any help will b e appreca.itied
Tx Jim
10-17-2006 14:37:39
 Re: 2240 or 2840 in reply to piston, 10-16-2006 12:34:46
With my experience of 20+ years service at a JD dealer which was during New 2840 sales I would rate the 2840 right behind the 2010/1010 diesel in reliabillity. Tx Jim
j cook (iowa)
10-17-2006 14:55:36
 Re: 2240 or 2840 in reply to Tx Jim, 10-17-2006 14:37:39
I heard that the 2840 was NOT reccomended for use with a loader. Also, the 2040, 2240, and 2840 were exclusively Mannheim built tractors. The 2440 and 2640 were US built, in Dubuque, until 1980. The 2840 worth owning was called the 2940, although I am unclear on exactly what the improvements were. If you want to own an 80hp tractor from John Deere, of that vintage, buy the 4030, or else the 90hp 4040.
Tx Jim
10-18-2006 03:34:50
 Re: 2240 or 2840 in reply to j cook (iowa), 10-17-2006 14:55:36
2840,2940,2950 & 2955's all needed a loader frame that went back to rear axle housing to keep from breaking clutch housing. 2840's were hard to start after running because of hyd's and weak starters. My experience with the rest of Mannheim built JD's for USA was good.
j cook (iowa)
10-16-2006 14:35:27
Do you want 50hp or do you want 80hp? You could also consider the 2040 (40hp), the 2440 (60hp) and the 2640 (70hp).
