430 oil pump
Donald Scott
10-16-2006 11:51:50
Does anyone know how the oil pump is fastened in on a 430 John Deere. I need to pull the cam but I don't know how to get the oil pump out. Any help would be appreciated. Thanks
Henry M
10-16-2006 15:26:59
 Re: 430 oil pump in reply to Donald Scott, 10-16-2006 11:51:50
Scott
Have you looked up to where the shaft housing of the pump attaches to the block. Should be two stud bolts there.
Keep in mind that if you put the pump back in without removing teh distributor you will probably break something because the distributor is driven by the slot in the top of the oil pump.
