HYDRULIC PUMP ON 0
amo
10-16-2006 10:53:44
WHAT DO YOU HAVE TO DO TO REPLACE THE PUMP ON A J D 40? CAN YOU JUST GO INTO THE TRACTOR FROM THE REAR OR DOE IT NEED TO BE SPLIT? I HAVE ACCESS TO A MANUAL ON M BUT NOT ON 40'S.
Mike M
10-16-2006 11:14:45
 Re: HYDRULIC PUMP ON 0 in reply to amo, 10-16-2006 10:53:44
It should be pretty much like the M. It is mounted up front on the engine,you should see the hyd. pipes going into it.Just unbolt enough stuff out of the way to get it out. Not all of the bolts in the pump hold it to the engine only 3 or 4 ? can't remember for sure ?
