Mark, Hydraulics "aint my thing" but hey thats never stopped me from an opinion right lol If you want that A to pull 3 x 16 fast enough to flop the dirt over well, I hope youre not plowing real deep and have loose or sandy soil and maybe even run a dual on the left side????? but hey "go for it" sounds like things Ive tried before lol On the Hydraulics, in the normal stock power trol configuration you use selector valve/spools so the hydraulic prressure flow is diverted to EITHER the internal cylinder to raise the rock shafts (your added 3 point) orrrrr rr to operate a remote hydraulic cylnder via those couplers buttttt tttt nottttt ttttt both..... And if I recall correctly when I tried something like you wanna do years ago (raise rock shafts PLUS operate a remote cylinder) it acted like the other gent posted in that the rock shaft had to lift fully BEFORE any pressure was then sent to the remote cylinders. AND DONT FORGET UNLESS YOU ADD IT ITS NOT LIVE HYDRAULICS EITHER Is that a steerable semi mount type plow where you raise the front with the 3 point and then the tail/gauge wheel lowers (with remote cylinder) to lift the rear of the plow out of the ground?? I dont think Hydraulic things are gonna work real well unless n until you add a Baker Valve on back the Power Trol PLUSSSSS SS I dont like to put any hard heavy pull on those rock shafts anyway, I see them more for lifting cultivators or using something light like a grader blade or small mower AND ESPECIALLY since youre trying to pull 3 x 16 off them !!!!! ! anddddd dd theres no real draft control similar to what a real 3 point hitch uses,,,,, ,,,,, Dont believe me however on the hydraulics you need the Frankster or another Hydraulics Guru to explain all the Baker Valve n Hydraulics stuff but I just dont see an A with an add on (fake) 3 point doin all that well trying to use a semi mount steerable hydraulic lifted rear wheel type of plow ESPECIALLY a 3 x 16????? ?? Hopefully someone will prove me wrong and youre off to the races. Good Luck n best wishes Let us know John T
