bad day
70D
10-16-2006 05:44:27
Question I was starting My 70 Diesel the other day when it was cold and had trouble getting the pony to rev up and when I try starting the big motor black oil crap came out of the exhaust of the pony is this just because I let the big motor turn with the trottle ahead and not starting it or am I sucking oil from some place then when I went to check the problem with the pony I;m only getting spark on the back set of points is this a bad coil or what any help is always greatful
Blksmok
10-16-2006 07:17:42
 Re: bad day in reply to 70D, 10-16-2006 05:44:27
70D...the black residue from the pony exhaust is from two cylinders sucking in raw gas and exhausting it w/o burning it. Could be a bad coil, condensor or points. Also, check your crankcase oil on the pony engine to make sure it has not been diluted with gasoline.
70D
10-16-2006 13:05:39
 Re: bad day in reply to Blksmok, 10-16-2006 07:17:42
Hey where is a good place to buy coils at I know i've seen them for about half of what Deere get but I don't remeber where I seen them at
F-I-T
10-17-2006 12:10:12
 Re: bad day in reply to 70D, 10-16-2006 13:05:39
The plastic covered, made outside the USA seem to run around $55 apiece. Magneeders has them, as do Sharp's, Taylor Equipment in Sears, MI, 'bout everyone who sells reproduction parts.
