48-A Engine knock.
Sam Schudi
10-16-2006 04:09:35
Loud knocking suddenly came out of my 48-A. There was some smoke out of the crankcase breather just as the noise started. Pulled the top inspection plate off, turned her over by hand and there is clearly play in the left connecting rob bearing, some disscoloration on the crank like it go hot and a few visible metal shavings. Haven't pulled it apart yet.
I am what I consider better than the average backyard mechanic, but have never rebuilt one of these old 2-cylinders. How far should I take this rebuild before I get into real trouble? Check compression to determine if I need Rings, honing, sleeves, valves, valve guides, or none of the above?
Sam
Glen in TX
10-16-2006 18:45:19
 Re: 48-A Engine knock. in reply to Sam Schudi, 10-16-2006 04:09:35
Sounds like to me from the way you described the spun out rod bearing you will know what else needs fixed as you see it going along. Also get yourself armed with a I&T JD-4 shop manual and a parts manual and operators manual are good to have too. This site and many other vendors sell the I&T manuals and parts catalogs available from JD and copies from others also. The I&T manual is good to have and covers JD A,B,D,G & H styled series tractors and some had the same engines in later unstyled and some didn't. The SM2000 toted as a service manual by JD and others it not what you really want and only covers electrical, carbs, & valve specs. You can get the rods rebabitted or exchange for rods already rebuilt. If exchanging rods be sure the piston pins fit right and aren't worn on that end. The crank could just need turning down some and shims taken out of rods resizing but if it got that hot probably needs spray welded building back up and turned back down to fit rods then. A good experienced local machine shop can help with all that.
Sam Schudi
10-16-2006 20:07:09
 Re: 48-A Engine knock. in reply to Glen in TX, 10-16-2006 18:45:19
Thanks Glen for all the confidence building and advice....
Sam
