410 lose of pressure
ChrisB
10-15-2006 14:25:40
Hi all. I spent the good part of the weekend stratching my head over this 1979 John Deere 410.
I blew the rear end in the spring. Had a kid help me repair it and he pulled the backhoe off to get to the rear end. Well I get the rearend installed last week and take it about 100' without the backhoe (lines plugged). Seemed to be plenty of pressure and speed on the hydralics. Then one of the front loader tilt hoses blew. No problem I get a new one made and replaced it. Refilled oil. No pressue or movement. From time to time I will get a small movement but not much. Pump is new and has about 200 hours on it if that. I am getting a reading of about 1000psi on a gauge that I have connected to the pump, but do not trust the gauge.
I have changed the hydralic filter, cleaned the screen still no luck. I also connected the backhoe up and can get some decent lift out of the pads but not that fast.
Any ideas as to what I might look for next?
Thanks,
Chris
Roy Suomi
10-15-2006 19:36:33
 Re: 410 lose of pressure in reply to ChrisB, 10-15-2006 14:25:40
Get out your tech manual and look up the filter relief valve..Pull it out and look at it carefully..There's probably just some crud in it holding it open ever so slightly..Doesn't take much to put this valve out of commission..Last one I did , I couldn't see anything wrong with it till I looked at the end of it and the valve was held open and not on its seat.I took it apart and didn't find anything.After a cleaning it operated smoothly and restored full pressure..
chirsb
10-16-2006 14:29:31
 Re: 410 loss of pressure in reply to Roy Suomi, 10-15-2006 19:36:33
Well I took out the filter relief valve and the Surge relief valve today. No change. Also replaced the trany filter as well. Still no luck.
At a loss as to how blowing a hose on good working hydro would cause this. Unless there was some excess dirt in there during the rear end change out that was flown through during the hose blow out.
I did not take the entire filter housing off, just the two vavles and cleaned them. Did seem to be really dirty at all.
Not sure if the pressure control valve or the pump stroke control valve filter is next. It looks almost as if you have to drop the front end to get to the pump vavle. What a crappy design.
Unless of course anyone has a better suggestion where to go next.
Would be VERY grateful for any advice.
Thanks,
Chris
