John Deere 440 Ignition timing
Joe Daugherty
10-14-2006 18:50:16
I have timed the oil pump like the book states now when i try to time the dist. the drive grove in the oil pump is not excatly parallel with crankshaft like the book says any advice ? Thanks Joe
HenryM
10-15-2006 05:22:17
 Re: John Deere 440 Ignition timing in reply to Joe Daugherty, 10-14-2006 18:50:16
Joe
I have found that mine was not exactly parallel with the crank, but close.
If you want to get picky like I did you can (the no one must be on tdc on the firing stroke) drop the dist in and do the static timing like the book says and see exactly where the distributor will wind up when the ignition is final timed.
That word timing can be a little misleading since what is really being set is the rotational position of the dist so the wires line up right for the coil and hot to the dist.
So if you want to change the final position a tooth one way or the other to your liking, you can put a big screwdriver blade in the oil pump slot and hold the bottom of the pump up with the other hand and while lowering the pump put a little pressure on the direction you want to jump a tooth with the screwdriver just as the teeth disengage you can gently move it one tooth and reinsert it and see how you like the position then.
you got to be having fun!
Joe Daugherty
10-15-2006 06:50:04
 Re: John Deere 440 Ignition timing in reply to HenryM, 10-15-2006 05:22:17
Thanks for the help.You told me what i needed to know.I was afraid of having the timing off and it kicking back and breaking the starter housing.You are correct that i am having fun because this 440 is in a crawler that i'm restoring Thanks Joe In Alabama
