DUAL loader on 70
Bob seND
10-14-2006 16:53:19
I've got my PowerTrol pressure line plumbed through the spool valve assembly for my DUAL 325 loader. It is a bit slower than the PTO pump, but acceptable if I can plumb in a larger reservoir. Can I just cut the return line from the PowerTrol and put an open T into the bottom of my loader reservoir? or will the return fluid from the loader cylinders then overfill the PowerTrol reservoir before it flows into the extra reservoir? If I had live PTO I wouldn't be doing this.
Thanks.
Bob seND
buickanddeere
10-15-2006 19:29:26
 Re: DUAL loader on 70 in reply to Bob seND, 10-14-2006 16:53:19
Use a couple more hoses and plumb the lift cylinders for down pressure. End of problem.
Bob seND
10-15-2006 20:22:55
 Re: DUAL loader on 70 in reply to buickanddeere, 10-15-2006 19:29:26
I don't really understand that, but my cylinders do have down pressure as it will lift the front end of the tractor off the ground.
Bob seND
Tx Jim
10-16-2006 04:25:28
 Re: DUAL loader on 70 in reply to Bob seND, 10-15-2006 20:22:55
Yes I think your powertrol reservoir will overflow if hooked to loader reservoir. I agree with BuickandDeere that if your cylinders are double-acting then the opossite side of piston in cylinder not under pressure acts as a reservoir. You might add a live hyd punp between govenor and mag/dist to utilize the reservoir on loader. Tx Jim
Bob seND
10-19-2006 21:07:55
 Re: DUAL loader on 70 in reply to Tx Jim, 10-16-2006 04:25:28
Jim, Yup, the PowerTrol overflowed. One more trial before going back to the PTO pump. I'm going to plumb the spool valve to the pump using the DUAL reservoir completely bypassing the PowerTrol reservoir. I'll get by without the outlets and rockshaft as long as the loader is on.
Not ideal, but I know that will work.
Bob seND
Bob seND
10-16-2006 08:07:08
Jim, I agree as I understand two-way cylinders, however this is what happened: I plumbed the hydraulic pump through the spool valve and only used the PowerTrol reservoir. The loader would only lift about 6 feet in the air. I added fluid to the PowerTrol reservoir until it flowed out the petcock and the loader went up to about 12 feet. I added more using the same procedure until the loader and bucket would both fully extend. You guessed it! When I let the loader down, the top seal on the PowerTrol reservoir blew and oil shot out the back about 50 ft. I drained out the excess oil, and I'm back to the low-lift loader. Both the bucket arms and the loader arms are two-way cylinders but they somehow need additional reservoir capacity. I'm going to trial and error the T from the PowerTrol return line into the bottom of the DuAl reservoir, but likely I'll have the overflow problem again. Are those pumps you mentioned available for the two-cylinder tractors? I've seen them on the SuperMs.
Thanks Bob seND
