JD 2240 shifting
Wayne Patoka
10-14-2006 16:40:45
My JD 2240 shifts good when I first start using the tractor but after it warms up both the gear and reverse to forward shift levers become very hard to move in and out of gear. I use Fleet Farm JD trans-hydrolic fluid. Would changing to JD Hy-guard improve the sticky shift? I there an additive I could add to the trans oil to make it shift better?
Pete/ME
10-15-2006 03:33:43
 Re: JD 2240 shifting in reply to Wayne Patoka, 10-14-2006 16:40:45
First thing I'd do is drain and change oil, (I always use "Hy-Gard") new filters and clean screen. Then check manual for clutch adj. If the pilot bearing was pooched, wouldn't it shift hard all the time?
MSM
10-15-2006 02:08:55
Sounds like the clutch is not releasing properly,pilot bearing is seizing up or there is oil on the clutch. Changing the hydraulic oil won't have any effect on the shifting.
