420 S smoke
BobBama
10-14-2006 06:36:49
Just bought a 420 Standard that is really nice .I mowed 2 acres with a 60 in. finish mower. The tractor holds a good oil press. 35 lbs. hot or cold.No smoke while running or mowing except when I throttle down.Then a lot of blue smoke.When throttle is pulled back to mowing rpms,after a few seconds no smoke at all.Any suggestions.
buickanddeere
10-15-2006 19:30:36
 Re: 420 S smoke in reply to BobBama, 10-14-2006 06:36:49
Where is the carb idle screw? Cranked in or out?
BobBama
10-14-2006 16:16:25
Thanks to all. I checked with a John Deere mechanic and he agreed with you.Thanks again. Bob
Henry M
10-14-2006 14:37:31
My 420 head came back from the mqachine shop with the bonnet oil seals on top of the valve stems, so it is possible and must have not been a big challenge since they did not even mention the addition.
I guess if you wanted to tackle it you could do the compressed air deal in the sparker hole and fit them on what you got.
JP in FL
10-14-2006 08:00:46
My 420 does the same, I figure bad valve guide seals. When the throttle closes, engine vac. pulls built up oil around the guide seals. Jim
CPeter
10-14-2006 08:51:04
 Re: 420 S smoke in reply to JP in FL, 10-14-2006 08:00:46
Bad valve guides. There aren't any seals like a modern engine. I have heard of people retrofitting them with Chevy seals, but have not seen one in person.
This is a common problem (if you call it a problem) and nothing to get too concerned about.
CPeter
