Can you ID this JD generator for me?
Way Up Here
10-13-2006 11:23:35
I have here a generator that I assume is from a John Deere tractor (since it was painted JD green and that was the only paint it's ever seen by the looks of it). It is a smaller sized generator, a Delco Remy model 1101859 6A 9 which I have checked to be a 6 volt generator with a 20 amp rating. It has an armature post (A) and a field post (F) coming out of the case and it is a two-brush styled generator. No regulator came with it. Can anyone here help me with these two questions:
1. If it is truly a JD generator, what model was it used on?
2. Can anyone tell me what specific regulator model should go with this generator? Or failing that, what general type, would it be a 3-coil/tower regulator or a 2-coil/tower regulator?
Thanks for your help !!
Glen in TX
10-13-2006 13:21:56
 Re: Can you ID this JD generator for me? in reply to Way Up Here, 10-13-2006 11:23:35
JD 40 tractor with Delco 1118308 regulator or
JD 320,330,420,430 with 1118780 regulator.
Way Up Here
10-14-2006 05:57:21
 Re: Can you ID this JD generator for me? in reply to Glen in TX, 10-13-2006 13:21:56
Thank you Glen, are those 2-tower or 3-tower regulators?
Glen in TX
10-14-2006 08:36:41
 Re: Can you ID this JD generator for me? in reply to Way Up Here, 10-14-2006 05:57:21
Both those regulators are 2 coil type units, 6V, Positive ground, 4 terminal: BAT., FLD., GEN., & L. The 4th "L" terminal goes to fuse and lights if you aren't familar with that type. Both Delco regulator numbers will sub over to a Borg Warner R195 regulator many auto supplies will have.
Way Up Here
10-14-2006 12:59:55
 Re: Can you ID this JD generator for me? in reply to Glen in TX, 10-14-2006 08:36:41
Perfect .... once again I thank you for your help. The little Allis B I have is going back to 6-volts with a generator from a 12 volt alternator conversion that somebody did.
