Hy-guard
Greg A
10-13-2006 07:35:32
Can JD Hy-guard oil be used in a hydralic wood splitter.
johns48b
10-15-2006 17:31:09
 Re: Hy-guard in reply to Greg A, 10-13-2006 07:35:32
i know this is a jd forum, but never use valvoline hyd fluid in an ih tractor. it will eat the lining off of the pto clutch packs.
jdemaris
10-14-2006 05:52:43
In warmer climates, it's fine. Only trouble with standard Hyguard for hydraulics is cold weather. Deere makes a cold-weather version of Hyguard for such use. The standard stuff is a little too thick for temps below 10 degrees F. With most tractors, it doens't matter much - especially Deere with closed-center systems - since the oil heats up pretty fast. But . . . we had problems with machines with gear-pumps - especially crawlers. Many 350s/450s would break the filter-relief valve peg from cold starting with standard Hyguard. Considering the price of Hyguard - in either version - you're way ahead to buy some cheaper 10W hydraulic oil. That all being said - I've got Hyguard in my three-point hitch splitter. That - only because it was all I had at the time when I needed to fill the thing. If I try to use it when it's 10 degrees F out - it squawks something awful until it warms up.
buckeye al
10-13-2006 14:13:36
I know a guy that used to have periodic and rather frequent difficulty with the clutch packs in the limited slip rear axle of his Dodge 4WD pickup. Seems they'd get dirty & start sticking and not behaving properly. After the warranty was off he thought much like Bob says, if it's good enough for his 4WD JD tractor costing several times what the truck costs, it ought to be good 'nuff for the Dodge!
No trouble after that! Stayed clean, worked right, still there!
I'd not hesitate a minute to use it in the wood splitter!
Bob
10-13-2006 07:51:57
Certainly. If it's good enough for a $150,000 machine, it's certainly NOT gonna hurt a $500.00 splitter!
Mike M
10-13-2006 07:50:35
I'm sure it can be used anywhere you use reg. hyd. fluid. I even use it in my air compressor and it is great to oil small electric motors it is very good oil.
