2640 hydraulic problems
tony guinn
10-12-2006 20:14:21
The hydraulics on my 2640 are not working properly. everything is very slow and the loader will work and then stop. If you don't use any hydraulics for a while they will work for a few seconds but then slow and even stop. When I engage the pto it is delayed and then starts slowly and will eventally will fully engage. When pto is engaged other hyd. functions barely work. I but a set of larger used cylinders on the loader and after installation if found that the internal seals were bad in one of the cylinders. When I had them rebuilt I was told that the seals in one of the cylinders were completely gone. I took the oil pump intake screen out and found hundreds of pieces of what I think were the seals. All sizes from 1/8 inch to little specs. Like a dummy I didn't replace trans./hyd. filter while I had it drained. I also noticed that when tractor is running that the hyd. oil appears to have tiny air bubbles in it. These bubbles dissapear after the tractor is shut down for a few minutes. Could trans./hyd filter be so plugged that the pump is starving and putting air in oil, or do I have a much bigger problem :-(. If anyone has any helpful advise please respond. Hate to bite the big one and send it to JD shop and pay the big bucks!!!!!
K.B.-826
10-12-2006 21:42:18
 Re: 2640 hydraulic problems in reply to tony guinn, 10-12-2006 20:14:21
Replace the filter first. No need to have the oil drained to do that. You say that it acts up especially when the PTO is engaged. That could be a very bad thing, could be an internal leak requiring the tractor to be split between the transmission and clutch housing. The utility tractors are somewhat known for having problems in that area.
tony guinn
10-13-2006 03:14:10
 Re: 2640 hydraulic problems in reply to K.B.-826, 10-12-2006 21:42:18
I have the problem all the time, just worse when pto is engaged. it acts like it builds up presure but can"t maintain it. Any use of hyd. loader, steering, 3pt. arm will work for few seconds and then slow and get jerky. what do you think about the air in the hyd. oil. If I use the tractor for extended period the oil on the dip stick almost looks foamy.
Tx Jim
10-13-2006 04:01:00
 Re: 2640 hydraulic problems in reply to tony guinn, 10-13-2006 03:14:10
Sounds like your oil is foaming. Is hyd oil correct for a JD if not change it. You also probably have a high pressure to sump leak. How is loader plumbed to tractor as some ind. spool valves can cause problem. Feel of hyd functions after running for excessive heat. A good place for internal leak is the rockshaft control valves. Look in hyd. filler hole for oil spraying. Tx Jim
tony guinn
10-13-2006 08:02:08
 Re: 2640 hydraulic problems in reply to Tx Jim, 10-13-2006 04:01:00
loader is on ind control valve. inlet comes from discharge from front pump. return to trans filter housing. JD shop told me that the stuff I found on the pump inlet screen is probably from brakes. they say that it could not be seals from loader as these large pieces would be in trans filter housing and not inlet pump screen. they say brakes had deteriated and fallen apart. they recomend complete oil and filter changes. and also cleaning of small screen on hyd. pump. They also say that if pump is starving for oil that it will create that air in oil problem. I will look in the oil filler hole for spray. thanks for the help..... ..
tony guinn
10-14-2006 03:37:50
 Re: 2640 hydraulic problems in reply to tony guinn, 10-13-2006 08:02:08
Got It fixed!!!! changed hyd oil and all filters.
trans filter was really plugged. works like new!!! thanks to all.
cannonball
10-14-2006 06:19:35
 Re: 2640 hydraulic problems in reply to tony guinn, 10-14-2006 03:37:50
If that screen had brake material in it, no you don't have it fixed... if you don't fix brakes then fine metal will be the next thing to stop up filter....have nice day
MAY GOD BLESS THE USA
