60 Splined End Crankshaft specifications
Fred from MO
10-12-2006 16:55:25
Would anyone have what the factory specs should be for the splined end of a 60 crankshaft. I was hoping to measure my splines to see how worn they are.
Mike M
10-13-2006 04:45:19
 Re: 60 Splined End Crankshaft specifications in reply to Fred from MO, 10-12-2006 16:55:25
You may want to clarify which end as both are splined. Unless both of yours are shot as that is VERY common on those.
Fred from MO
10-13-2006 11:02:45
 Re: 60 Splined End Crankshaft specifications in reply to Mike M, 10-13-2006 04:45:19
Sorry you are correct. I am interested in the clutch side specifications.
Thanks
F-I-T
10-13-2006 11:46:20
 Re: 60 Splined End Crankshaft specifications in reply to Fred from MO, 10-13-2006 11:02:45
Fred:
Are you wanting to know the width of the splines, or the angle of the taper, or both?
The farthest portion inward should be untouched from new as it was never contacted by the driver, right? So you should be able to mike the male splines and slide two angled parallels in the notch if you don't have a caliper to get the slot width. On the slope of the taper, measuring a fresh clutch driver would be one way to get this, since I'm not sure that it is a standard taper like from a Morse number. Measure the rise over a marked run of say and inch to get the slope.
Frank
