JD 50 ignition coil
Jack OH
10-12-2006 16:16:00
The coil went bad on my 50, so I went to Autozone cause they were the only ones open,and bought a 12V coil. The new coil says "for electronic ignition". I put it in and it started, then it began missing ,then it died. It has no spark now. Are electronic ignition coils not compatible with points type ignition?
I"m pretty sure the coil is bad because the 50 died while I was mowing from no spark. So I put the coil from my Farmall Cub in it and mowed a couple more hours with no problem.
Thanks
Jack
Jack OH
10-13-2006 16:46:54
 Re: JD 50 ignition coil in reply to Jack OH, 10-12-2006 16:16:00
Thanks John, I got a look today and the points are burned up. So I took that coil back and got the right one. I'll get some points tomorrow.
Jack
John T
10-12-2006 19:23:32
Jack, Some of the high energy coils designed for use with electronic switches are of lower primary impedance then the old fashioned points type 12 volt coils which are around 3 ohms. They would work but the points would burn up quick. Other solid state use ignition coils were fired by a higher voltage short duration pulse versus the regular old 12 volt conduct n saturate types used on point ignitions. If you bought a so called electronic ignition coil and wanted to use it with points, the main thing is its primary resistance being in the vicinity of 2.5 to 4 ohms which should enable it to at least work without burning the points, although if its designed for use with a higher voltage short duration pulse your spark energy may not be all that great.
You need to go to NAPA or Central Tractor or Rural King etc or Mother Deere and get a coil intended for the old points ignitions or else convert to electronic ignition n be done with it maybe????? ? Also get a true full 12 volt rated coil if youre at 12 volts with no external ballast resistor. The coils labeled 12 volts for use with an external ballast are in reality 6 volt coils and will overheat if ran at 12 volts and not ballasted. The 12 volt coil would be labeled 12 volts or 12 volts NO external ballast required
John T
