37 D stalls
Major 1911
10-12-2006 16:10:59
I am trying to get my 37 D running. After it sits for a while it starts right up. Once it starts to warm up it stalls under any load. Just driving up the slight slop of the driveway, then it is very hard to get started again.
Glen in TX
10-13-2006 08:53:01
 Re: 37 D stalls in reply to Major 1911, 10-12-2006 16:10:59
You are going to have to do more trouble shooting to narrow it down some. Open carb bowl drain and see if you have good fuel flow? Steady pencil size stream for a good minute or more while catching the fuel. If not look for crud in tank, plugged sediment bowl or lines. See how it runs with the air intake off as maybe air cleaner is plugged up. Still has a good hot blue spark after it dies? Plugs black sooty fuel fouled from running rich? Running metallic core spark plug wires and non resistor plugs? Not enough air or carb problems and then pull carb down and go thru or send it to someone to rebuild it. Post back and let us know what you find. Some more tips for carb on this link for JD H but tests will apply to your carb too.
Anderson
10-12-2006 19:00:25
Sounds like carburetor problems to me.
