3130 all systems . . .stop
Gerry IRL
10-12-2006 03:23:20
Neighbour's 3130 was mowing one day when firstly the clutch wouldn't engage - he could depress the pedal and the tractor would travel on. Later that day, all systems ceased ... no lift, no power steering, no PTO, no gears. It sounds catastrophic to me, but I told him I would check with you good folk.
Gerry IRL
R. John Johnson
10-12-2006 05:04:23
 Re: 3130 all systems . . .stop in reply to Gerry IRL, 10-12-2006 03:23:20
Loss of all hydraulic functions could also be the splines in the pump coupler stripping out. If this happened suddenlly then I would look here first. I don't know if the 3130 has a hydraulic clutch or uses mechanical linkage. Either way it sounds like two different problems to me.
John
Tx Jim
10-12-2006 04:21:08
I think the clutch operates the same as on a 2940 which has a master and slave cylinder. Remove cowling in front of dash and look for a resovoir. On Hyd's and trannsmission I would tend to suspect tranns. pump as that operates pto and hi-lo. Has he changed hyd filter and cleaned sump screen? Tx Jim
