3020 gas to diesel swap
Lincoln
10-11-2006 16:41:58
I may need to rebuild my 1966 3020 gas motor. Was thinking I would rather have a diesel. What problems would I run into changing it over to a diesel motor?
Mike Aylward
10-12-2006 09:40:25
 Re: 3020 gas to diesel swap in reply to Lincoln, 10-11-2006 16:41:58
Linclon, I have done this swap and it can be done but it really is not cost effective to do so. IF you can find a good, reasonable engine (good luck) it can be done. But in all honesty, it would be easier and cheaper to just trade your tractor for a diesel. It is easier and you will not have a "hybrid" to get rid of down the road. My opinion. Mike
buickanddeere
10-11-2006 21:02:48
Four cylinder Waterloo diesels are getting scarce. The Dubuque four cylinders will bolt into a Waterloo if you can find a salvage 2510/2520/4030. You will need the front engine support, bellhousing too.
960
10-11-2006 18:14:26
Or sell the 66 gas , add your diesel budget and maybe a few $ and buy a 69-72 3020 diesel then you have something. Unless the diesel is free you will have more time in it than it is worth.
buickanddeere
10-11-2006 17:10:01
Too old and too small to sink that kind of time & $$$ into. Sell the 3020, take that cash and your engine swap budget. And make a down payment on a 4WD 5105 and turn the pump up to the 5205's HP level.
