The front valve for 4010 and 4020 may be similar for the early 4020 but the connections out back are not the same. The later 4020 used the predecissors of what was used for 25 or 30 years with the valve out back too. Getting the parts from a sort of reputable rebuilder runs about $500, maybe 600 these days. Tapping pressure as Mike suggests works. Take the elbow with you to find the correct one. Cost me big bucks to special order the wrong one based on JD parts. The filter cover with an oil return port was first made for the 2640. That cover is more than $60 from Deere, a flow restrictor valve (that is part of the original valve) is handy, maybe $35, and a single hydraulic valve (has to be CLOSED center) runs maybe $140. Add hoses and hardware, maybe a $110 Pioneer dual connector and you are still cheaper than used Deere parts. I have made those connections and I run a loader and back hoe that way. I should post a picture of mine someday but its kind of grubby from working for a living. If I was to add a valve (if I didn't make it part of the loader valve where I wish one valve had float) I'd mount a shelf just elbow high in the right fender (not a console 4020) and bolt the valve underneath with the ports pointing down. Then I'd reverse the handle (s) to reach above that shelf. Gerald J.
