G Head Repair - Is this right??
triplow07
10-10-2006 19:41:29
I stopped by a small local shop to look at a JD-G. The G had a cracked head and had antifreeze getting into the cylinders. The mechanic had used a hand grinder to grind the cracks. He was grinding down into the water jacket next to the valve seats. He was then pinning the grinds. Does this mechanic know something I do not? If the tractor was mine, I would have found a different head. I hope the owner knows what is going on with his tractor. Is this a satisfactory method of fixing cracks?
40 JD G
10-11-2006 18:09:16
 Re: G Head Repair - Is this right?? in reply to triplow07, 10-10-2006 19:41:29
I have a head off of a styled G if you are looking for one, it is not cracked complete with valves and springs. The valves hardly have any whare but will need ground due to some small pitting. Let me know if you would be interested
JLG
10-11-2006 14:44:59
I just had one fixed and they brazed it. He told me it'll last forever now. I tried to buy a good used one first, and had no luck at all. By the time I finally bought one, off of a running tractor, I took it in to get checked out and it had the starts of a crack in the exact same spot. Finally I just told them to weld it and get it done.
Mr Mark
10-10-2006 20:23:11
I have had several 2 cylinder heads repaired
with the pinning method. All have been just fine.
J Schwiebert
10-10-2006 19:47:21
I have "pinned" several John Deere G heads with good luck. I am not sure if I understand all the grinding, but I did not see the crack either. More questions? J/
triplow07
10-10-2006 20:15:53
 Re: G Head Repair - Is this right?? in reply to J Schwiebert, 10-10-2006 19:47:21
I heard of drilling and pinning, but not grinding.
