4320 INJECTOR REMOVAL
John in Md.
10-10-2006 16:35:29
Trying to remove a Bosch KDL injector from a 4320 row crop. Shop manual says use special tool JDE-69 or JDE-69A to remove gland nut. Any ideas where to get one of these special tools or a suitable alternative? The counterman at the deere dealer sent me to the shop foreman who told me they don't lend tools and they are NLA, any ideas.
John in Md.
10-11-2006 11:16:49
 Re: 4320 INJECTOR REMOVAL in reply to John in Md., 10-10-2006 16:35:29
OK, I called the dealer back. If you look up JDE69 (not JDE-69)they can order for $35.55 plus shipping and 2-3 week wait. Thanks for the input. John
Mike M
10-11-2006 04:39:30
I got an el cheapo small slide hammer set that sometimes works on injectors.
Matt871
10-10-2006 21:09:59
Look up Apex Tool Company, P/N DOTC-7458 $100.07
Glen in TX
10-10-2006 19:08:47
Yep try another another dealer. Dealer here keeps those wrenches in stock hanging on tool racks. They know if they don't we'll go someplace else. Dealer has a special site they can go to for ordering tools. I've seen them do it to get me a pump nut wrench before.
K.B.-826
10-10-2006 18:30:04
Sounds like that dealer is trying to trick you into paying them to do it for you. I can't believe that tool isn't avalible, a bunch of 4430's and 4630's also had those injectors. And that tool does wear out/gets damaged. Those injectors can really fight. Either the gland nut will be seized into the head or the nut will be seized to the injector. Might require a little heat/tapping the nut with hammer and punch. Last 4320 I had the injectors out of, all came right out except #3, which was hopelessly stuck. I had to remove the oil cooler to make room to work. Make sure to put a light coat of never-seeze between the injector and the gland nut, and also on the gland nut threads. Also make sure the o-ring that goes against the top of the gland nut is in place.
matthies
10-10-2006 18:11:08
Go to a different dealer, I bought one last year. chris
