Good tractor for rototiller
Trent M
10-10-2006 13:23:26
I'm looking to get a good older tractor to use with a rototiller. My classic tractors are all red, but if I buy a tractor 1960+, it WILL be green! Any suggestions or hints? I need for it to be able to "crawl" or go slow. I would like to use a 5 ft.+ wide tiller and maybe do some other things like bush hog. Will need to have 3pt hitch. Any suggestions on HP PTO etc.? Also, since I'm not well versed on JD numbered tractors, any help on which models I should look at is appreciated.
Thanks.
jdemaris
10-11-2006 06:42:37
 Re: Good tractor for rototiller in reply to Trent M, 10-10-2006 13:23:26
If you've got hard ground - then having the low-low first gear is essential. For a smaller JD utility tractor - you can't beat a 1020 or 2020 (300 or 400 if painted yellow). There are also the more-German versions of the 1020 - e.g. 820 or 830. I've used a five-foot tiller here in hard-pan central New York. It was miserable when I tried it on my Case DC, Case VAC, Case VAH, Case VA14 International B-275, International B-414, 8N Ford, etc. But - on my Deere 1020 it works great - real nice creeper gear. Also works nicely on my other Ford 8N that has the optional Sherman aux. trans. - but the Ford is nowhere as nice to use as the Deere 1020 - since the latter has power steering, power brakes, independent PTO, more power, etc. Same goes for a rear-mounted PTO powered snowblower. Having a fast-only reverse is awful to use.
5450
10-11-2006 06:17:15
I have a 72" tiller with my 50, It is all it wants but if you go easy and have the ground plowed prior, it does an excellent job. If you are looking for a post 1960 model, I would suggest nothing less than a 1020. (1010 will work but the 1020 has more bugs worked out of it) Good luck!
Brendon
10-11-2006 03:57:21
I would sure look for something with a very slow first gear, something less than 2 mph. Many vintage tractors had a 2 to 3 mph first gear that would be too fast for tilling.
Pete/ME
10-11-2006 03:51:31
Pretty much depends upon the ground and the h.p. rating of the tiller. There"s cheap tillers out there that would probably be alright for cultivating well-worked loam, and others, like the "Howard Select-a-Tilth" that could break hardpan. I broke sod with a 4020D PS and a Howard in third gear. If you don"t want to go that big, I"d look at 2240, 2440"s, common, dependable and can be found for around $10k
JDK
10-10-2006 15:40:44
I have been using a 5 foot tiller on a 1951 JD B. Been working a 2 acre garden for about 10 years. Plowed ground is best for starting out. I wouldnt try busting sod with the tiller and the B. It's just too much for both tractor and tiller. The B is about 27 HP. The 5 footer is about all it needs to handle. I am very happy with the way it works the dirt and will continue using this combination for years to come. I do a couple of the neighbors gardens every spring also. A '50','520' or '530' would be minimum for 5 foot tiller is my opinion.
