Bolt location on sway block 4020 cat 2 to cat1?
Nylon
10-09-2006 21:19:05
Switched my sway blocks from cat 2 to cat 1 position thinking that it should be so simple. Well it isn't bad but am confused. There is only one recessed hole for the square nut to sit in in the cat1 position. There are a total of 3 holes that are available thru the sway blocks..they are spaced perfectly except that of the 3 only 2 could be used at any one time because of the arc in the bolt pattern. But again only one hole per block is recessed for the nut so the arms can slide by. How should these mount up? With only one bolt in, the lower bracket to the drawbar hitch is able to pivot a bit till the drawbar stops it. The other holes have a small recess from the nut sliding into the casting for the cat 2 position. It may be possible that the cat 1 set up only needs the one bolt but seems kinda sloppy that way and wouldn't think deere would have liked that. Any info would be much appreciated as usual.
Thanks,
John
Glen in TX
10-09-2006 22:10:17
 Re: Bolt location on sway block 4020 cat 2 to cat1 in reply to Nylon, 10-09-2006 21:19:05
Every John Deere operators manual from the 2 cylinder 20 series on up thru the new generation tractors and later shows and describes with pictures how to position the sway blocks. You only use one bolt on each one when they are swung upwards on top bolt to allow sway for working but no sway when up during transporting. Otherwise you always have two bolts in each block. Try turning them over or getting them on the correct side.
third party image
third party image
Nylon
10-10-2006 00:59:24
 Re: Bolt location on sway block 4020 cat 2 to cat1 in reply to Glen in TX, 10-09-2006 22:10:17
Glen,
Thanks for the info. I have the blocks on the right and left side as they are labled. If you turn the block to the cat 1 surface, (narrow) you have one flat surface and one contoured surface. The flat surface has to mate to the PTO/drawbar housing. That leaves only the contoured surface out. The problem is however that there is only 1 recessed hole in each block to take the square nut in the cat 1 side. There are two other holes that line up and correspond to the housing holes but....you are looking at the end on view for the cat 2 square nuts that slide into place from the end. I wish I had a cam.
I should mention that I do have the operators manual and I have the same pic you have of the rear blocks installed. Those pics however do not show where the bolts are attached. If you put a bolt in either of the other holes that are not recessed the nuts or bolt heads will protrude into the path of the drag links being raised or lowered. I do not want sway at any postion. I have the blocks positioned to work as such.
One bolt location is obvious by the recess. With that bolt in place you can pivot the block top or bottom towards you about 1/2 inch. And line up either the hole above or the hole below but not both at the same time. But as I mentioned neither hole has a recess on the drag link contoured side to allow the drag links to pass over them. There in lies the cunundrum.
ERIC BENTON
10-10-2006 06:39:51
 Re: Bolt location on sway block 4020 cat 2 to cat1 in reply to Nylon, 10-10-2006 00:59:24
I went out and looked at my 3020 and there is not a nut in the lower corners. The first bolt up above the drawbar slot holds the sway block on the tractor. The 4020 frame is different from the 4010 shown in the above picture.
Mike M
10-10-2006 06:09:08
It's been awhile ,but I seem to remember ? that at the top you have a special bolt with a round shoulder and a 12 piont head and these just act as dowel pins to locate the top and just one bolt at the bottom holds them on.
ERIC BENTON
10-10-2006 05:56:40
The 4020 sway block is only held on by 1 bolt regardless of the position of the swayblock. there is a dial pin at the top of the swayblock that holds the top of the swayblock in place. If you look at the above picture in the corner of the frame right above the drawbar slot you can see a nut screwed on a bolt. this does not attach to the sway block. The bolt about an inch above it will go through the housing and through the sway block and screw into a square nut that fits into an indentation just for the nut. There will not be anything sticking out past the edge of the sway block. The picture above is of a 3010 or 4010 tractor and the swayblocks are different. The bolt in them screws into the swayblock and do not have a seperate square nut.It is a simple change from cat 1 to cat 2, one bolt and 10-15 minutes.
Glen in TX
10-10-2006 08:20:14
 Re: Bolt location on sway block 4020 cat 2 to cat1 in reply to ERIC BENTON, 10-10-2006 05:56:40
The pics above came from a 3010 book but may be of some other tractor? Was too late when I posted that above. Yes, you are both right that they had a dowel bolt / pin locator on top and only 1 bolts was used on each side on later ones. He could have the wrong blocks ? Need new bolts or nuts or chase the threads some. I seem to remember always needing penetrating oil and wire brush and maybe a tap or die to chase threads when the blocks hadn't been changed in a long while and then it wasn't a 5 minute job. lol. Dirt and rust gets between them and into threads. The lower bolts on some used bushings and some didn't. That may be your problem too Nylon with not the correct length bolts or missing bushing. Check the parts catalog for your serial number to see.
Nylon
10-10-2006 12:41:26
 Re: Bolt location on sway block 4020 cat 2 to cat1 in reply to Glen in TX, 10-10-2006 08:20:14
Hey Guys,
Great info. I knew I wasnt dreaming this up ;]
Anyway I know that my blocks have a round indentation and I bet I am missing that stud. Whover put these blocks on before I got the tractor had the one corect bolt used but also bolted thru the lower blocks and thru the narrow drawbar thickness brackets. There is a longer bolt passage that isnt threaded for the big square nut and bolt. That is where that bolt goes..but I dont have the stud that keeps the blocks from pivoting near the top. These blocks have no threaded holes in them anywhere...so that I have to figure out is an actual 4020 block set then. My manual has the same picture that you sent me so don't feel bad.
Thanks again to all you other guys too.
John
Ferd
10-10-2006 16:31:47
 Re: Bolt location on sway block 4020 cat 2 to cat1 in reply to Nylon, 10-10-2006 12:41:26
On my 68 (old style) 4020 the bolt threads into the sway block. On my 69 4020 (new style with side console) there is a bolt and a nut. If I remember, in Cat. II position, the nut slides into a slot that goes through the sway block and the bolt threads into the nut. In Cat. I, the nut fits in a recess on the edge of the sway block. The sway block has to be rotated 180 degrees (rotate top to bottom) to go from Cat. I to II.
Nylon
10-11-2006 17:54:02
 Re: Bolt location on sway block 4020 cat 2 to cat1 in reply to Ferd, 10-10-2006 16:31:47
Ferd,
I have a 68 4020 but I must have the 69-later blocks. I have no threads in my blocks. the cat 2 side has the places for sliding in the square nut from the sides...you can see them in the photo above too. Cat 1 position just has the one recess for the nut. The hitch bracket that the bolt goes through to mount the blocks is about a 2 inch +/- solid sleeve..not seen in the photos above. It is slightly above the top drawbar crossmember.
Thanks for all the great info guys. There appears to be several different variations across years, similar models and same models. Mine appears to be mix and match which I bet is the case for alot of folks.
Glen in TX
10-10-2006 15:01:17
Those studs could have rusted and broke off too. I've seen that and the lower bolts rust or break too so probably a good time to check and replace all the bolts if needed on drawbar support too. I was thinking of the 20 & 30 series 2 cylinders that do use 2 bolts on each sway block.
