1940 BR
HaroldIHC
10-09-2006 21:09:53
Hi all, What should a person pay for 1940 BR? The engine is stuck,needs paint,rear rims are rusted out. Tractor has good tires and strait tin. Thanks in advance.-----Harold
James Howell
10-12-2006 09:47:20
 Re: 1940 BR in reply to HaroldIHC, 10-09-2006 21:09:53
Hello Harold.
I bought a 1940 B for $600. The motor is stuck. It was missing the sparkplug loom and clutch cover. I bought a lower water pipe to replace the existing hose.
The main reason I bought the tractor was for the near perfect 36" JD 1470R round spoke wheels. I "spruced up" the wheels and put them on my 43B.
My long range plan is to rebuild the 40 B called "LAZARUS" as a working tractor.
If you want the 40 BR for parts, consider the shipping costs involved with every part you may need for your "working" tractor.
If you are going to use it for a "working" tractor, then you can rebuild to suit your needs.
If you are going to use it for a "show" tractor, then you might need a pair of pants with deep pockets.
I am not concerned what my tractors may be worth to others, only what they are worth to me as working tractors on my farm.
Yesterday at the State Fair of Texas I priced several new JD tractors with less HP than my old boys. By my calculations, I figured that the price on 1 new JD tractor would buy at least 2 or 3 good antique JD tractors with more HP.
Bottom line is what the tractor is worth to you for what you want to do with it. Good luck with your decision.
D-Man
10-10-2006 04:22:59
What you think the tractor is worth is up to you as an individual. You can compare what others are selling for in the same condition, but not all are the same condition. Look at what needs to be fixed and repaired and get yourself a ballpark figure on what that is going to cost you. Sounds to me it is a complete teardown,which could get more expensive than what the tractor is worth, depending on your time and labor. It is your own wise judgement as to a value of a tractor.
