1936 unstyled B tread width
Russell S.
10-09-2006 07:19:49
Can anyone tell me how to run in the wheels on a 36 B? They are so tight and rusted I can not move them. Any ideas?
DickD
10-14-2006 02:57:40
 Re: 1936 unstyled B tread width in reply to Russell S., 10-09-2006 07:19:49
Loosening the wheel and driving it till it started to move always worked for us, but sometimed loosening was not all the problem. I have seen tin cut and put under the collars or sprinkle salt on the axles to get the wheels to hold, so once you change positions of the wheel, watch them closely after tightening them that they don't move.
Russell S.
10-16-2006 03:24:05
 Re: 1936 unstyled B tread width in reply to DickD, 10-14-2006 02:57:40
Thanks for all your help. I am still trying and may need more help but I do appreciate it.
Russell
CalJim
10-09-2006 21:51:31
Russell,
We removed the rear cutoffs on a 36 B this summer. It was a lengthy battle to say the
least. We tried Kroil penetrant for weeks
with intermittent heat and pounding with
a small sledge. Ended up with our neighbor's
huge rosebud tip and a full size sledge.
I made a puller with some 1" steel plate
and hardened allthread, plate started to
bend. Somewhere the combination of all those
"methods" finally broke them loose. The rust
in the splines had expanded,locking the
wheel on the axle. It's exactly what every-
one says, PATIENCE is the key. CalJim
ebbsspeed
10-09-2006 11:55:18
Can you get the clamp bolts loose? If so, I've heard of guys having some luck just loosening them a bit and taking the machine for a little ride over some rough ground to break the wheels free. Never tried it myself, I was lucky in that mine came loose pretty easily with just a couple weeks worth of soaking with PB Blaster.
