Blow by
fatbob50
10-08-2006 21:26:10
I have a John Deere 2940. The engine runs good and it does not smoke, but it has a lot of blow by. It smokes out of the blow by tube. What would cause this? After the tractor sits for a week, it is very hard to get it to start. It just turns over alot until it finally starts. Once it starts and runs for a bit, it is easy to restart. As long as it is started often it starts up ok. I appreciate any suggestions that are offered.
Bob
10-08-2006 21:37:54
 Re: Blow by in reply to fatbob50, 10-08-2006 21:26:10
Hard starting, after sitting a while, with a diesel, indicates the fuel is draining back to the tank, or leaking out of the pump, and being replaced by air. Since the tank is above the pump, it sounds like a fuel leak, allowing a litle fuel to seep out when running, and a little air to enter the system, when shut down for a few days.
Is there any sign of a fuel leak when running, at a fuel line connection, injector return line, or at the throttle shaft? Any sign of diesel fuel entering the crankcase, adn thinning the oil?
