Help; Adjusting Oil Pressure
Gord in Ma
10-08-2006 21:24:35
I have what I believe to be a 42 B, (missing serial #) it has a cast frame. The oil adjustment is in the crankcase on top of the oil filter housing. Question is, which way do you turn it? What is the best way to do this? I recently replaced the oil pressure gauge after replacing some oil lines in the crankcase. When I started the tractor the pressure read between low and medium, closer to low. So, I shut the tractor down. Is there a way to check the pressure besides with the guage? I appreciate any advice you can offer.
Glen in TX
10-09-2006 10:25:56
 Re: Help; Adjusting Oil Pressure in reply to Gord in Ma, 10-08-2006 21:24:35
Try another guage as your other one might be faulty. Should have 10-15 psi with another marked guage with oil at operating temperature and high idle or with JD guage between M and H. If not turn the screw in clockwise for more pressure or out for less.
Gord in MA
10-09-2006 12:25:30
 Re: Help; Adjusting Oil Pressure in reply to Glen in TX, 10-09-2006 10:25:56
Thank you Glen, I will get a numbered gauge and try that. Thanks again for the info!!
Glen in TX
10-09-2006 10:25:47
