Deere Power Steering
Bob (WA)
10-08-2006 13:46:57
A friend of mine told me that I might be able to adapt John Deere power steering to my old grader to help it steer better. Does anyone have pictures, drawings etc. that have enough detail so I can work this out?
A few pictures of the steering:
third party image
third party image
third party image
third party image
Thanks for the help,
Bob
'49 Adams 412H
Roland Jackson
10-11-2006 19:05:43
 Re: Deere Power Steering in reply to Bob (WA), 10-08-2006 13:46:57
Bob, you can go two ways...either use a Torque Generator where you splice the unit into the steering column...or you can have really good power steering by using a hydrostatic type steering. I would be glad to help you...my number is 620-357-6546.
Glen in TX
10-08-2006 19:42:51
You can find all kinds of brand new or surplus hydraulics, Char-Lynn torque generators, steering valves and steering columns in Surplus Center catalog.
Mike M
10-08-2006 15:32:28
I would suspect they were talking about an aftermarket unit commonly seen on Deere's. They were made by charlynn and belhen you just cut the steering shaft between the gearbox and steering wheel and it fits in there. Some kinda pump is needed to power it . They may still make these new or I bet you could find a used one on ebay.
CPeter
10-08-2006 14:56:51
I would look at the setup off a late 70s Ford 3/4 or 1 ton truck. It is self contained in the slave cylinder/ valve assembly and only requires a generic PS pump to drive it. They are pretty common. This style may have been used on other trucks as well. I have on off a Mustang, but it is too small for that size machine.
CPeter
