Power Steering Play in a 301A
BJ Davis
10-08-2006 06:17:47
I have a 301A industrial tractor with power steering. There seems to be excessive play in the steering. I had to remove the power steering valve housing to replace a gasket. I have to turn the steering wheel about a quarter turn (90 degrees) before I see a response in the tie rod assembly on the other end. Is this normal. If not, what is the best way to fix the problem.
Thanks in advance.
Knoxville TN.
Roy Suomi
10-08-2006 07:08:47
 Re: Power Steering Play in a 301A in reply to BJ Davis, 10-08-2006 06:17:47
Is that 1/4 turn running or off?? Considering what it costs for steering valves , as long as you can steer it reasonably , I'd leave it alone..Is there any slop on the end of the " dogbone" that attaches the steering to the cross shaft ??
BJ Davis
10-08-2006 11:15:15
 Re: Power Steering Play in a 301A in reply to Roy Suomi, 10-08-2006 07:08:47
The 1/4 turn is with the power steering valve housing completly off the tractor. There does not seem to be excessive slop in any the other linkages.
Thoughts?
Roy Suomi
10-08-2006 13:09:36
 Re: Power Steering Play in a 301A in reply to BJ Davis, 10-08-2006 11:15:15
Oh heck...I thought it was on the tractor....Don't worry about it..It takes oil pressure to center things up on the main shaft..Works ok running doesn't it?? Dont mess with it...
