46B, can you replace the pistons and leave the rod
Phillip W.
10-07-2006 20:13:03
I was wondering if it is possible to pull the cylinder jugs off, have them bored and replace the pistons without having to pull the governor housing and everything else off to rods out with the pistons?
Mike n Mo
10-08-2006 05:54:49
 Re: 46B, can you replace the pistons and leave the in reply to Phillip W. , 10-07-2006 20:13:03
You don't need to take the governor off to pull the rods, just the top crankcase cover. To remove the block on a '46 you have to be in there anyway to remove the oil line to the back of the block that supplies oil to the rocker arms. If you don't have a manual, I suggest getting one, either from Deere or IT. The IT service should be around $20. Good luck, Mike
johns48b
10-07-2006 20:27:01
you'll have to pull the rods out. you have to use a ring squeezer to put the pistons back in and you can't do it without pulling the rods. if your going that far into an engine you need to mic the journals and rod bearings at the least.
