Diesel in the crank case
Willy Gropp
10-07-2006 13:58:42
My father has had his old 720 for more years than I can count. Just recently, however, we noticed that when the tractor has sat for a while, fuel is somehow draining into the crank case. Any ideas on what might be the problem?
Mike M
10-08-2006 15:38:32
 Re: Diesel in the crank case in reply to Willy Gropp, 10-07-2006 13:58:42
The transfer pump is has a weep hole in the bottom of it so if it leaks it should run out on top of the main case and make a mess you can see.
JD man in SD
10-07-2006 18:18:54
i would replace seal in the transfer pump first not likely to leak at pumps unless engine is running. lines between pump & inj do brake some times lol Kent
msb
10-07-2006 19:42:23
 Re: Diesel in the crank case in reply to JD man in SD, 10-07-2006 18:18:54
I agree with SD. If it is leaking when setting, it is most likely the transfer pump seal. The copper delivery valve holder gaskets are notorious for eroding and cracking from the high pressure of the injection pumps, but they usually won't leak very much when setting.If the pumps are leaking , the area under the pumps should show it. Remove the pump cover and have a look for evidence of drips or washing of the metal under the pumps. I would be very careful if you try to tighten the delivery valve holders.Too much torque can split the pump housing.
Mike M
10-07-2006 17:53:33
I had a few that did that and was able to help them by tightening the injection pump delivery valves. This is the large end where the line hooks on it took a big wrench 1 1/4" or 1 1/2" ?
