No Spark to 3020 gas
Illinois Farmal
10-07-2006 10:59:31
Have narrowed my problem with my 3020 gas to it not having any spark. I just replaced the coil and all that did was empty my checking account of $35.00. This is my first JD tractor so I'm not very familiar with them. I haven't found any obvious broken wires/bad connections. Any help would be greatly appreciated.
Illinois Farmall
10-07-2006 14:01:56
 Found the Problem!!!!!!!!!!!!!!!! in reply to Illinois Farmall, 10-07-2006 10:59:31
Well, I finally broke down and pulled the hood and all of the panels and started tracing wires in depth. Didn't take me long to find a rats nest buried under the hood. Splices, splices and more splices...and chaffed wires. I replaced the worst ones and cleaned it up the best I could without doing a complete rewire. Hit the starter and she roared to life!!! Next on the agenda....new wiring harnesses. Thanks to everyone for all of their help. This forum is great!
Glen in TX
10-07-2006 14:11:16
 Re: Found the Problem!!!!!!!!!!!!!!!! in reply to Illinois Farmall, 10-07-2006 14:01:56
Glad you found it. Yep, been there and remember now that harness under hood with mess of lines going forward is famous for shorting right under where edge of hood and dash panel meet.
http://jdparts.deere.com (parts catalog on left once there)
Agri Services has harnesses also.
Glen in TX
10-07-2006 13:53:39
 Re: No Spark to 3020 gas in reply to Illinois Farmall, 10-07-2006 10:59:31
How many volts do have to coil? Enough? None? Just no spark right off coil output or at distributor only? Back track to the switch and check it out as it could be bad too.
