3pt and a loader
MaryK
10-06-2006 20:19:36
We just purchased a JD60 with a loader, and would like to also put on our 3pt (from a JDB), but the rockshaft will not turn. Can we run both? and/or what do we need to do?
Dean A. Van Peursem
10-07-2006 00:05:17
 Re: 3pt and a loader in reply to MaryK, 10-06-2006 20:19:36
You will need to add a Baker Valve or add a live hydraulic pump between the governor and the distributor or add a PTO shaft driven hydraulic pump to run the loader. Then install dummy plugs in the Power-trol and then the rock shaft should work.
The first numbered series only allows the rock shaft to work or the hydraulic outlets but not both simultaneously.
