Float Ride Seat stiffen adjustment?
Nylon
10-06-2006 19:03:03
Discoverd I have a float ride seat that was stuck all the way down and didn't float. I am able to turn the adjuster nut righty tighty all the way to where it comes out of the threads. Lefty loosy, I can only turn it so far because the threads are gunked up from years of neglect. I did manage to turn it a ways though. Which way tightens the compression on the seat? Righty tighty or lefty loosy? Also the seat is a bit "tippy" as in it sways side to side quite a bit...any tips on snugging this up?
Thanks much,
John
Ferd
10-08-2006 15:08:00
 Re: Float Ride Seat stiffen adjustment? in reply to Nylon, 10-06-2006 19:03:03
The 4020 seat has a counterbalance cable that often unhooks. Until it's hooked in the right place near the back of the slanted housing below the seat, the counterbanance screw adjustment won't work. It's hard to see and hard to hook up. If you don't have a manual, you might see if your local John Deere dealer can show you in his parts book.
Mike M
10-06-2006 19:21:12
Is this on your 4020 ????
I've only done one and it has been a long time ago. I just pulled the whole thing off and worked on it on the bench. I do think ? there is some nylon rollers on each side and that may be the source of the side play. I got everything freed up so it adjusts and slides back and everything.
Nylon
10-07-2006 17:58:04
 Re: Float Ride Seat stiffen adjustment? in reply to Mike M, 10-06-2006 19:21:12
Thanks for the info. The manual calls it a float ride and yes it is on 4020. It says to adjust float tension with the front nut and look at the side indicator to see if it is set right for your weight. The cab tin covers the indicator so I cant tell which way to go. I want to stiffen it so that it doesnt bottom out and stick in the down position as it had been ever since I owned it and figured it out the other day. Typically you righty tighty to stiffen things but that doesnt seem to be the case here. I can only move the threads so far as they are gunked up going the lefty loosy way. I ran the threads right out of the nut turning it righty tighty.
Thanks Again,
John
