I have a different opinion on your wheel question. I don't know what brand that mower is, it could be an old Sunflower (we had a 9'pull-type in 1960 that would make a our gas "A" really talk) but I would be inclined to only add a single, center-line mounted, gauge wheel. On a three point mower such as this, the weight is supposed to be carried on the two front pins attached to the tractors lift arms. On an older tractor without variable depth control, full down was the only position you could depnd on, so the lift links were adjusted so that the mower would be at the correct mowing level when the three point was all the way down. This allowed the weight of the unit to be carried by the tractor. One reason people have such durability problems with the tail wheels is that they fail to adjust the top link to carry the weight that otherwise falls to the rear, as well as to keep the mower level from front to back, asking the tail wheel to carry substantial weight full-time, rather than act as a gauge or anti-scalp wheel only when a front to back depression is being crossed. Just like on your lawn mower deck, the deck is supposed to be suspended from the tractor and the gauge wheels, which are really anti-scalp wheels, to only touch intermittently in order to guard against the deck going too low. Back to the field mower, in the early days, they didn't even use a tail wheel, just back skids for "anti-scalp" control. This is the type of mower you have pictured. If that mower was installed correctly, with the lift links bottomed out and then shortened to hold the correct depth, and the top link was adjusted to carry the weight and level fore and aft, it should do just fine. If your ground is rough, some folks use a telescoping top link and that will allow the top link to compress when you climb up and out of a depression. Some even use a chain in lieu of a top link, but I am not a fan of those. If you do add a tail wheel, a centerline unit will keep you from twisting the frame and deck steel if you drop into a lateral depression. Early users of those units found was that if you dropped one side of the tractor in a hole, the mower edge on the side stayed up on the ground with the weight of the tractor trying to hang on it. This put a real bind on the mower frame. Since the early three points did not always have the option for a "float" position, that edge pushed up on the lift arm, which again, did not always have much upward float. This put the whole contraption in a heckuva bind, often twisting the whole unit. Same thing happens if you were to install two wheels on the rear. If you drop in a significant depression with your right tractor wheel, the left rear mower wheel comes off of the ground and that half of the mower rear weight is hanging on the left rear of the mower. When they went to a gauge wheel mounted on the centerline, if the mower dropped into a depression, the mower could tilt to the left or right along its longitudinal axis, riding on the edge of the single wheel only, functioning as a pivot. The only twin wheeled rotary mowers I have ever seen or used were pull type, but they had a pivot of sorts, because of the clearance of the hitch pin in the drawbar hole. Since three points determine a plane, I believe this is why the centerline mounted single tail wheel is the design that you see today on a semi-mounted or fully-mounted mowers. Twin wheels are used when there is only one draw point, so that three points are always on the ground. You could use two rear wheels, but they should really pivot in the center so that they are always on the ground, and if they are, why not use a single wheel which guarantees that to always be the case. Now, nothing beats being quick on the draw and lifting the mower a bit when you encounter a depression so you don't have those twisting forces to contend with. Take a piece of cardboard and tape it to your model tractor on your desk (everyone has one there, right?). I think you'll see what I mean as you force the cardboard mower upward from each rear corner. Just my opinion. Your mileage may vary.
