1520 speed control lever rebuild
Marshall Vidri
10-06-2006 08:22:41
The speed control lever on my JD 1520 has the tension spring broken into three pieces, the friction washers are badly worn and soaked in oil, & the two grommets that hold the shaft steady are worn out. I have disassembled the shaft and gotten the replacement parts from John Deere. Here's my problem: when I went to pick up the parts, the mechanic told me reassembling the unit is going to be tough. Does anyone who has done this on the 20 series diesels have any advice or tips?
machinery-man
10-06-2006 10:33:25
 Re: 1520 speed control lever rebuild in reply to Marshall Vidrine, 10-06-2006 08:22:41
been there done that. The tough part is compressing spring and I found a small set of vise grip. Get them on with good bite then tap them down to hold spring tension worked for me. I use a smooth rod to tap them down. Also you can use them to compress the roll pins. Hope this help....if I were there would show you how...
Bob
10-06-2006 10:07:07
That DOES look annoying to do!
Third Party Image
I recently worked on my 424 IH, which is similar. Outside of skinning a couple of knuckles a bit, in the tight confines under the dash.
Good luck!
