70 flywheel seal
Animal
10-05-2006 16:58:11
I have to change out this seal I have done many of the corks and the letter series but have never tackled any of these the book says to center it up with shim stock, is their any secrets that I should know about, also what about frozen brakes the shoes stuck to the drum has any one found any thing better than beat and heat? thanks for the info in advance i appreciate it guys.
Mike M
10-06-2006 07:24:53
 Re: 70 flywheel seal in reply to Animal, 10-05-2006 16:58:11
Do you have a 70 gas or diesel ? A gas model should be like the letter series you have done before. You center the slinger cover around the slinger with shim stock or a feeler gauge then tighten it up. If a diesel you may have issues with setting the end play as the slinger cover has shims behind it to control endplay. You may find some broken or missing thrust washers. Instead of a thick cork you will have a thinner square rubber packing that fits in a groove the same way.Not really any different designed.
