4430 leaking hydraulic fluid
chris meredith
10-05-2006 16:49:02
i have a 4430 that is leaking hydraulic fluid out around where the lift arms conect my dealer told me that it was nt to much problim to fix so i took out he snap rigs on both side drove the saft back remove the old seals but when i try to put news ones in i wound up breaking two of them no getting eather side fix any one no how to put them in easy anyone ever did that if so please let me no
Glen in TX
10-06-2006 12:01:29
 Re: 4430 leaking hydraulic fluid in reply to chris meredith, 10-05-2006 16:49:02
You need to check the holes and bushings in wish bone piece for wear too and shim the side to side play out of it also. JD has the shims for that too.
G/MAN
10-06-2006 07:48:36
You need to get yourself a manual before you ruin more parts. Also, just replacing the seals is just a band-aid. If the shaft and/or bushings in the differential case and drawbar support are worn, and they most likely are, those new seals won't last long at all.
John in Md.
10-05-2006 16:58:37
If you're talking about the load control shaft seals, try putting them in a pan of hot(not boiling) water to soften them up, makes them easier to slip in.
