4020 Hydraulic problems
DEAN GILLESPIE
10-05-2006 09:44:49
We have a 1964 4020 gas tractor with a loader on it. At times the loader works fine and 5 minutes later it may shake or not work at all. When it does not work we do not have any steering also. We will put it in park and 5 - 10 sec. it will make a clattering noise and will start to work again but shake and go up slowly. If we extend the bucket cylinders all the way and hold for 5 seconds it will work right untill you get ready to dump again. When we start the tractor it takes 10 seconds before the 3 point arms lift and they shake. We have overhauled the front hyd. pump;a spring up next to the fire wall dealing with the power steering; changed filters; cleaned the screen down by the transmission. We was told that to check the charge pump was to let out on the clutch with the bolt left out where the clean screen is. It was working. Can the charge pump by the transmission be the problem and only work part of the time? Or could it be an air problem?
Gerald J.
10-05-2006 10:34:57
 Re: 4020 Hydraulic problems in reply to DEAN GILLESPIE, 10-05-2006 09:44:49
If you loose hydraulics with the clutch pedal pushed in, it can be the check valve between the charge pump and the oil reservoir up front letting that reservoir drain. There is a JD service information that changes an elbow in that circuit to a check valve making the repair a great deal easier to accomplish than fixing the original valve deep in the transmission. I have information on my web page>Link
I've>Link done the procedure to my '68 4020 and I have hydraulics immediately on starting even while still holding the clutch pedal down even after the tractor has sat for months.
There is a test procedure for the charge pump in the I&T manual. It involves opening the plumbing and adding a restrictive valve and gauge and checking the flow and pressure.
Gerald J.
