JD 2020 clutch fork/lever replacement
telephoneman
10-05-2006 03:43:27
While checking this newly aquired tractor I found that one of the 3 clutch/pressure plate forks was broken. I checked with JD and the part is available. Is there a best way to replace it? Looks like it could be done thru the access hole. Any help would be apprecited.
buickanddeere
10-05-2006 03:49:50
 Re: JD 2020 clutch fork/lever replacement in reply to telephoneman, 10-05-2006 03:43:27
Bite the bullent and split the tractor. At that age and hours everything inside needs looking at.
telephoneman
10-05-2006 15:07:34
 Re: JD 2020 clutch fork/lever replacement in reply to buickanddeere, 10-05-2006 03:49:50
Never have split one but it looks like this may be my first.Thank you for the reply.
