3020 gas update
Illinois Farmal
10-04-2006 18:21:45
Today the John Deere man brought back the rebuilt carb and it fired right up and after a few adjustments ran better than it ever has....no hesitations....no stalling. After he left I fired the old picker up and less than 10 minutes later.....sputter sputter bang! Now it won't start again. However, when trying to start it I was on the ground leaning against it and THOUGHT I felt a tingle run thru my arm sooooo o.....come daylight it's time to start tracing wires. Any particular places that are common for failure??? If nothing else, I got a rebuilt carb out of it.
Roger in Iowa
10-05-2006 23:57:11
 Re: 3020 gas update in reply to Illinois Farmall, 10-04-2006 18:21:45
There is an electric solenoid on the carb to shut off fuel when you turn off the key. This prevents it from "dieseling". Is the wire loose? If loose, it will shut off the fuel.
Roger in Iowa
Dave Sherburne NY
10-05-2006 19:21:34
A few years ago, my SIL had a 3020 and it would
do this. Turned out it was a jet inside the Carb that loosened up. Did it twice over the years he
owned it.
buickanddeere
10-04-2006 20:02:43
Dirty fuel?
