STUCK Aluminum Piston
Larry Jensen
10-04-2006 16:38:24
I am working on a 49 John Deere B with aluminum pistons and one is stuck. We have gone as far as pulling the block and trying to press it out in a press. So far no results. Any suggestions? Do I dare heat the cylinder. I can reach in from the water inlet on top and thru the drain plug on the bottom.
Jack OH
10-05-2006 12:41:27
 Re: STUCK Aluminum Piston in reply to Larry Jensen, 10-04-2006 16:38:24
Try some vinegar, let it set for a day or two if you can.
Jack
F-I-T
10-05-2006 14:17:58
 Re: STUCK Aluminum Piston in reply to Jack OH, 10-05-2006 12:41:27
Boy, I'm not too sure about that option. I wouldn't expose aluminum to vinegar at all. Even though weak, it is Acetic Acid, and aluminum erodes fast enough as it is. I think if it gets through to the first ring and goes no further, you risk having still stuck pistons full of acetic acid boiling away, with a chance of an eroded first ring land.
Just my 2 cents.
F-I-T
10-04-2006 16:59:09
Larry:
You might be surprised what warming that block up with hot tap water might do. It's the cheapest trick to try. Hook a garden hose to your laundry sink, and turn the water heater up to the max. Bathe it until it gets as warm as the water will take it (sit it in a wash tub or better yet a cooler to insulate it from heat loss). Put a bit of dish soap in the water for a lube and it might penetrate down to the iron rings that are no doubt swollen with moisture in the carbon, and maybe some red rust as well. Don't use anything alkaline. If that does not work, you can move onto plan B which in my world would involve sitting it over a gas or charcoal grill, suspended by a cable or chain fall so that you can raise it up to temper the heating. I've seen them warmed using a couple of 400W heat lamps. A very large deep fryer would be ideal, as the hot oil would get into every thing! I once boiled one in a rendering pot.
Just don't go too hot. You know the drill. You're not dealing with cast iron.
Frank
tstex
10-05-2006 05:22:46
 Re: STUCK Aluminum Piston in reply to F-I-T, 10-04-2006 16:59:09
Frank,
On that last suggestion, what type of batter do you recommend that will stick best to the block for that golden-brown look? I think you are going to need the "Gensu" knife to cut and eat that block! lol
