1929 D #75049 piston and ring sizing
bmklawt
10-04-2006 10:31:28
I need an education before I start taking things apart.
I believe I need new rings and before I start I was hoping someone could educate me.
How big can the bore be and still use standard pistons?
If I need to go oversize to .045 or .090 should I choose one over the other? It�s in an occasional parade and hopefully will get to plow days once a year.
Also if I go oversize is there any thing else that needs to be changed or done?
Your input is much appreciated,
Bruce
Glen in TX
10-04-2006 10:53:00
 Re: 1929 D #75049 piston and ring sizing in reply to bmklawt, 10-04-2006 10:31:28
Bruce, The SMF116 that covers early Ds said to place a piston in middle of stoke and then put a ring against piston in cylinder measuring end gap. Says rings 1 & 2 should have end gap of .018-.024 and rings 3 & 4 a gap of 0.12-.018. If you need ridges or scoring in bore or ring grooves are worn bad may want to replace with either .045 or .090 pistons. If cylinder bore is okay yet you might get by with some light honing and using oversize rings on old pistons. There are places that can make or supply overwidth rings to fit worn grooves in piston too. Your 29 D should have 6 3/4" bore too though so more gap could be run and for late recommended piston skirt clearance was 6-10 but I've ran more with light honing and new rings or oversize rings and they ran fine too.
